Old 10-23-2009, 02:52 PM   #1
SoonerJeepMan
Member # 104975
TJ full cage/windshield ?
I have a full cage, tied into the frame....
it also is connected to the windshield at the top (like the original roll bar). I've seen some jeeps with full cage that are not connected to the windshield.
Wondering if not having the it connected will cause windshield rattle with the top on or off and windshield up? It would be beneficial if windshield was down when wheelin and taking 4 extra bolts out is a PITA...but doable if needed...
any experience with this?
SoonerJeepMan is offline   Reply With Quote
Old 10-23-2009, 03:08 PM   #2
YredJ
YredJ's Avatar
Member # 130903
I dont have a problem on my yj, and I only have one bolt in either side of the windsheild. I dosent rattle at all even when going down the highway.
STRAIGHT UP GANGSTA FAB!!! AIGHT BRUTHAS
YredJ is offline   Reply With Quote
Old 10-23-2009, 03:27 PM   #3
SoonerJeepMan
Member # 104975
ok, you talking on the side hinges by the mirrors (if ya have some)?
Old 10-23-2009, 03:57 PM   #4
Schvin
wheeler
Schvin's Avatar
Member # 117513
Send a message via AIM to Schvin
YJ's windshields don't have side bolts, they bolt on on the inside, like the CJ's, just that the holes don't line up perfectly, if I remember correctly.
Schvin is offline   Reply With Quote
Old 10-23-2009, 04:05 PM   #5
jeepinTY
jeepinTY's Avatar
Member # 73191
He is talking about where the original cage attaches to the top of the windshield. I have seen them with or without but unsure of how it does without. I am hoping to not have to brace mine.
jeepinTY is offline   Reply With Quote
Old 10-23-2009, 04:24 PM   #6
hurleygo3
Poser
hurleygo3's Avatar
Member # 80862
My windshield is not connected to the cage. It just has the one bolt on each hinge holding it. Its solid and doesn't rattle.
Barack Hussein Obama. Why stupid people should not vote.
hurleygo3 is offline   Reply With Quote
Old 10-23-2009, 04:38 PM   #7
Dookey
WINNAR!
Dookey's Avatar
Member # 23680
Send a message via AIM to Dookey
It shouldn't rattle at all. It is completely sitting on a rubber gasket. If it rattles... you have problems.
All you know about me is what I've sold you!
Old 10-27-2009, 10:42 AM   #8
froggytj
Member # 140187
I have a full cage not attatched to windshield and have had no problems with windshield rattle.
froggytj is offline   Reply With Quote
Old 10-27-2009, 11:28 AM   #9
mean green
MN GRN
Member # 62908
No probs either.
98 TJ
mean green is offline   Reply With Quote
Old 11-05-2009, 07:50 AM   #10
ioman2
slow ride
ioman2's Avatar
Member # 88231
if it rattles, just put a rag or an old glove in there to stop it.
this is where i show you how cool i am....
ioman2 is offline   Reply With Quote
Old 11-05-2009, 10:54 AM   #11
dirtyboots
Atrocious Driving
Member # 18123
rattlin'
OR Fab ties their A pillar cage into the top of the windshield with a tab coming off of the cage. If it bothered you check out the OR Fab and tack in a couple of tabs to support the top of the windshield off of your cage. There are probably other shops that do the same thing.
dirtyboots is offline   Reply With Quote
Old 11-06-2009, 09:06 AM   #12
tjdriver
Member # 79079
i have the or fab trail cage on my heep. the windshield tie in works great with my soft and hard tops and is super easy to disconnect to let the windshield down.
tjdriver is offline   Reply With Quote
Old 11-06-2009, 09:10 AM   #13
brownbagg
Member # 102
think of all those CJ that did not have roll bar connection, they only had the two hand bolts, they did not rattle.
brownbagg is offline   Reply With Quote
Old 11-06-2009, 05:45 PM   #14
kasbiker38
Member # 134106
my cage is not connected in my yj and i have no rattles.
kasbiker38 is offline   Reply With Quote
Old 11-07-2009, 12:28 AM   #15
furblog
Member # 121764
Wondering if not having the it connected will cause metro molded windshield seal rattle with the top on or off and windshield up? It would be beneficial if windshield was down when wheelin and taking 4 extra bolts out is a PITA...but doable if needed...
Well, my friend also got the same problem (almost). What can you say about these weird rattling sounds?
furblog is offline   Reply With Quote
Old 11-07-2009, 03:37 PM   #16
rubiweeler
Member # 111725
yep it wont rattle, mine isnt connected and doesent rattle
rubiweeler is offline   Reply With Quote
Old 11-07-2009, 06:36 PM   #17
flatlander757
Booger welder.
Member # 106845
Send a message via AIM to flatlander757
If you have a cage going across right behind the windshield(you have a full cage so this should be the case), what if you take one or two of the footman's loop straps(used for holding the windshield down when you have it folded forward) and tie them around the footman loop on the top/middle of the windshield and around the rollcage? Just put a slight tension on it.
Just an idea
Built D60 and D70 sitting in garage waiting to move into their new home under my 03 TJ.
Project "Get that Heep done before the wedding!!"
flatlander757 is offline   Reply With Quote
Old 11-08-2009, 09:20 PM   #18
MQ79
Member # 31410
Just an idea
That's all I do to keep my windshield up. Just the strap, no bolts or anything else, and it works fine.
MQ79 is offline   Reply With Quote
Old 11-08-2009, 10:20 PM   #19
2003_ram
Curb Cruncher
2003_ram's Avatar
Member # 127313
My Granddad runs his TJ with one bolt on the side hinges, it's perfectly fine. It doesn't rattle. Go beat your jeep.
Nobama, I don't mind working for my money, you shouldn't either.
Willys Build for whoever is interested --> http://pirate4x4.com/forum/showthread.php?t=824952
2003_ram is offline   Reply With Quote
Old 11-09-2009, 02:23 PM   #20
SoonerJeepMan
Member # 104975
thanks folks...took the bolts out...because my frickin driver's side door would not shut...guess my windshield got tweeked sometime...ah well...ended up having to jerry rig a spacer so my door could shut...only 3 bolts to take out to have windshield down!!!
Old 11-09-2009, 03:18 PM   #21
PDK
Newbie
Member # 114169
I'd like to hear some thoughts on the safety of only running the side bolts and no top windshield bolts. I've read where a few people strongly discourage losing the cage to top of windshield bolts.
PDK is offline   Reply With Quote
Old 11-09-2009, 03:23 PM   #22
SoonerJeepMan
Member # 104975
I had one guy tell me the windshield is actually (some %, maybe 15%) of your roll bar's strength...but then I have a full tied into the frame so that should be strong enough. Not sure if the strength thing is on a factory set up or not.
My reason for running without is purely from a standpoint that IF I want the windshield down when wheeling (to keep from smashing the crap out of it on a tree) then I won't have 6 bolts to take out, now I just have 3, should be 2 on the side but I've got to adjust windshield for the door to shut well.
seems like everyone here has no problems running with the windshield tied into the roll bar.
just my 2 cents...
