#1 |
STR8AXL
Member # 47541
How to seal exo tubes running through body
I found these seals at Earl's plumbing and used them to seal the tubes I ran from my exo through the side of the bed, and to the stock inner roll bar. I always wanted to do this but couldn't figure out a good way to seal it. These are the biggest ones they make and work perfect on 1 3/4 tubes. Thought someone else might be looking for something like this.
http://www.holley.com/types/Seals-It...et%20Seals.asp ![]()
85 Exo caged 4 Runner Stolen Aug 25 09 Santa Cruz http://pirate4x4.com/forum/showthrea...=stolen+85+exo Last edited by slabcrawler; 11-07-2008 at 09:06 PM. |
#2 |
Member # 47016
perrrrrrrrrfect! I was wondering that too. Will work great on my exo cage where a tube will run thru cab for me to bolt 5 points too.
1984 toy Ext cab/22r on 'pane/dual Ts/ARBs fr&rr/529s/High pinion front/36 Iroks on beadlocks/V6 rear end/63" chevy springs rear/44044 springs up front/13" bobbed box/longs and hub gears/ARP studs/Behind axle steering/Hydro assist CRAWLINBC.COM |
#3 |
Does yer dewg bite?
How much?
85' Toyota truck/runner. 60/14 bolt, 4.3L, 39.5's. 07' Turner RFX for exercise. (Ride hard or ride cross country) In loving memory of Madelyn Rose Ekhilevsky
04/17/04 - 12/08/08 |
#4 |
STR8AXL
Member # 47541
$20.00 each.
85 Exo caged 4 Runner Stolen Aug 25 09 Santa Cruz http://pirate4x4.com/forum/showthrea...=stolen+85+exo |
#5 |
Member # 481
Wow thats nice! Doesn't look like you can put them on after the fact though unless u cut and slit them lol!
Jason
Click Here For Awesome Metal Fabrication Equipment From BAILEIGH INDUSTRIAL |
#6 |
Member # 64778
I have used these ones before and they worked nice, $15.00 a piece, cant remember the site for where i got them from, i'll see if i can find it again...
![]() This place sells alot of different styles also,they have Split Grommets, like someone mentioned above for adding after a cage is already through the cab, but looks like the biggest of that style is 1". Gives you an idea though on how to make a set if you are that serious... Split Grommets Normal Grommets EDIT: Didnt realize the two links i gave at the bottom are for the same pictured in the first post, carry on. Last edited by Okiyota; 11-08-2008 at 08:07 PM. |
#7 |
Member # 80995
thats sweet. i wonder if the rubber will dry up and shrink over time and then future possible leaks.
#8 |
Member # 102813
Thanks Slabcrawler!
You even made it easy to find in a search with the title!
My friends call me "The butcher" I feel like I stole this bing from Billy....http://www.pirate4x4.com/forum/showthread.php?t=847699 |
#9 |
It looks like the ones for 1.5 tubing is $60 not $15. The little ones are $16 for little sizes.
#10 |
www.12voltguy.com
Member # 40
MaMaster Carr has something similar, I think all rubber
looked them up 2-3 years ago off a reply on here thought they were under $5 too bumped this because it was link in another thread might as well add this info
LOTS of GUNS 4sale ! 12voltguy.com / ![]() Click here to email me New # 530.532.4529![]() http://www.davezoffroadperformance.com/ OFN Fab BB -89 1 ton bronco on 47" LTB's-![]() Hard work often pays off after time, but laziness always pays off right now. |
#11 |
Member # 34860
I vote this to the FAQ.
92 4rnr 3.4 auto duals 37" PBR's 88 4rnr 3.0 stick soft top 33's stock |
#12 |
Drive a First Gen
Member # 89727
damned good bump...x2 on FAQ
'81 Trekker Wheel Responsibly, Don't screw it up for others... Remember to Thank a Vet |
#13 |
Frontier4x4.com
Member # 35054
I've left my open so far and it really doesn't get much water if any coming through being on the side of the truck. The little water that does dries up quick.
www.frontier4x4.com Luke Graham - (515)441-0338 Facebook Fan Page 85' 4Runner Weekend Warrior Build 88' DD 4runner Build Frontier 4x4's 83' Trail Rig Build |
#14 |
Member # 92391
great stuff
epanding foam works great
keep the wheels spinnin and the beavers grinnin.. |
