#1 | |
Cardboard Killer
Member # 5776
Chop saw notching 101 (With pictures)
search terms: chop saw chopsaw abrasive cuttoff 14" notching notch tube 1.75 miter coping fishmouth fish mouth hole saw
This is a recurring topic around here. I snapped a couple of pictures while doing some cage work today so we'd have somewhere to point anyone who asks from now on. First, a brief pictorial of a basic right-angle notch. That is 1-5/8" tubing in these pictures...
#2 | ||
Cardboard Killer
Member # 5776
Next, what angle do you set the chopsaw to? Hint: It usually takes a pair of cuts between 20 and 30 degrees for a 90-degree "T" joint like the one in the above picture. Using two 45 degree cuts seems to make sense as a place to start, but is actually FAR too much and will leave large gaps if you try it.
I've seen this posted by various people on here so I don't know who to credit for posting it on PBB first. But here's the info: Quote:
| Sponsored Links |
#3 | |
Cardboard Killer
Member # 5776
Last tip for now:
SAVE YOUR EMPTY PAPER TOWEL ROLLS! These thin cardboard tubes are almost the same diameter as a 1.75" piece of tubing. Notch tricky angles in the cardboard with scissors until you get it perfect. Then slit it lengthwise and slip it over the tube & copy it. It's a whole lot faster than notching the same tube 3 times. Plus it's free. ![]() You can get at least 5 notches out of one cardboard tube if you're careful.
#4 |
Member # 6957
thanks for this info. will definetly be used
#5 | |
Cardboard Killer
Member # 5776
No problem. We just plain needed a good pictorial. I used it for the first time yesterday, and will probably never borrow Dibble' JD2 notcher again unless the chopsaw dies or I've got a REALLY funky notch. This is so much simpler, easier, and definitely faster. I'm loving it so far.
![]() Feel free to add any other info you've gathered using this technique.
#6 |
Member # 16425
thanks for the tip!
#7 |
Well done. :bookmarking thread:
:Golfclap:
Nex Pro Evinco "Death Before Defeat" Last edited by Cue-Ball; 03-24-2006 at 07:16 AM. |
#8 |
Member # 14780
good stuff. since our notcher took a shit i've been doing the same thing with either the sawzall or the porta band. works great!
04.5 cummins lb,qc,white, 4x4,,bddl, outlook,, exhaust 315 bfg's 02 WRX caged etc new buggy http://www.pirate4x4.com/forum/showt...43#post5890143 save tellico post #830 |
#9 |
Member # 48607
If i remember correctly, Eric from FatCity built all his rigs with the chopsaw notcher. I know he did with my scout.
Big Sexy |
#10 | |
Member # 2870
With a lot of experience you can make every angle of cope no matter how extreme, without the use of a grinder, but I've been doing this for 15 years or so now. Important and most commonly over looked by many is the practice of deburring your tubes after you've coped, it will decrease blood shed and increase the look of profesionalism, and can also effect your weld (sort of) Eric Filar
FatCity Off-Road Racing WWW.FATCITYOFFROADRACING.COM |
#11 |
Rotten Sperm
Member # 63386
That's good to know (I'm to cheap to buy a notcher) thanks!
#12 | |
Good job I use my chop saw more than my notcher sometimes and grinder of course.
[SIZE="5"][COLOR="Blue"]www.rockjunkie.net[/COLOR][/SIZE] [URL="http://www.crackslinger.com/login.php"]http://www.crackslinger.com/login.php[/URL] [URL=http://www.pirate4x4.com/forum/showthread.php?t=313836]Link's to rockwell question's and info...[/URL] [URL="http://www.ouversonengineering.com/"][SIZE="5"]http://www.ouversonengineering.com/[/SIZE][/URL] Last edited by TheRipper; 03-25-2006 at 09:20 AM. |
#13 |
Member # 64758
Nice post.. good info..
guess it's time to go build that cage I've always wanted!!
#14 | |
I make guns
Member # 14561
Colorado Springs FFL-07/SOT
The Front Range Anti-Zombi Specialist Custom Rifles and Class-II/III EvilBlackRifleShop.com Inventory Reduction Sale I am selling off inventory, but I still sell/make a wide range of EBR parts, accessories, and fully functioning firearms. So PM for quotes. New Guns On Gun Broker "You worry too much, eat more Bacon!" |
#15 |
Newbie
space saver
Thanks for the good ideas. My garage doesn't have room for more tools. The more ways I can use the ones i've got the better
#16 |
I am still a little confused on how you achieve the base angle. I try to figure it out each time I see a post about chop saw notching and have yet to figure it out. I am probably just trying ot hard to figure out a simple solution. I know there are quite a few base angles listed above, but what if I am trying to fit two pieces of tube together that are not listed above?
97 TJ - 5.13's, 9" Detroit, HP44 ARB, 36" TSL's 06 TDI - Daily commuting duties Build Thread |
#17 | |
Cardboard Killer
Member # 5776
Start with the indicated angles for the closest sizes listed... and then notch a short piece of scrap or a paper towl tube with scissors. In other words, trial and error, buddy.
![]() There's a mathematical formula Jasonmt posted in one of the chopsaw-notch threads... but I'm not that smart nor patient. If you're off by 5 degrees (hell, the chopsaw has less accuracy than that to start with) a tap or two with a grinding wheel will fix it pretty quick. Something else: I bought a couple pieces of foam pipe insulation to pad my cage. You know, the stuff they tell you never to use to pad a cage? It's $2 for a 6-foot section, around 1.5" thick, and easy to cut. Might be a good thing to use as practice-notching foder if you don't have a paper towel tube or toiler paper tube handy.
#18 | |
Member # 48323
If you don't have firsthand experience, then I'm not really interested in what you think you know. ========================== 1985 xcab-dual cases-33"Truxus-ARBs-Longfield's-Wagoneer springs-Rancho 9000- ========================== |
#19 | |
Mellonhead
Member # 3236
For small stuff (under 2") I generally just eyeball it and then hit it with a cone stone on the grinder to get it to a acceptable fit. http://www.pirate4x4.com/forum/showp...2&postcount=44
Too many idiots, not enough dead people |
#20 |
heres a program that prints out templets that you wrap around the tube
http://home.tallships.ca/mspencer/winmiter.html
Penn State study finds that heavy drinking is 100% easier than giving a shit |
#21 |
Member # 70489
A subject which returns regularly is the "Pipe/tubing Notcher with chop saw".
Wishing to learn to program with Web, I made this small script. (Javascript, PHP ...). http://snip.awardspace.com/ Good notching. |
#22 | |
Member # 26440
It is a nice little program. I think it needs some tweeking. |
#23 | |
Mellonhead
Member # 3236
If you punch in 1.75" for the OD and 1.75" for the ID it is going to give you a 45 degree response. If you punch in 1.75" for the OD and 1.51" for the ID assuming that you are using 0.120"WT tube you get a "base angle" of 60.2/29.8 degrees.
Too many idiots, not enough dead people Last edited by jasonmt; 04-01-2006 at 11:18 PM. |
#24 |
Member # 70489
3 values are needed for the program to work.
od for the outside diameter of the main tube. Id for the inside diameter of the notched tube. angle for the connecting angle of tubes. You will obtain 2 angles of cutting. The table is a bonus summarizing some angles of connecting. Last edited by j13l; 04-02-2006 at 05:48 AM. |
#25 |
Member # 26440
Ahhh, thanks, sweet little program. It helps if I read the direstions huh?
| Thread Tools | |
| Display Modes | |
