Specs:
1989 Toyota Extended Cab 3.0 V6. 210k miles on the clock (porlly more, speedo doesnet agree with larger tires)
3" body lift. (might be cut in half later on)
5" Trail Gear IFS Elliminator kit
5" Trail Gear Classic rear kit
1985 Solid front Axle, 5.29's, Quick lock locker
Stock rear axle with 5.29's and Detroit locker
15/38.5/15 TSL Boggers
15x10 American Racing Black Waggy Wheels
Here is pics as it stands Stock, then 3" bl with 33's, then 4" sus/3" BL on q-78 Tsls, then now same but with 35x14.50 boggers. All this will be finally removed fos the last picture.
== Merged Post ==
Okay progress. I have the front third member locked and geared.
All un needed brackets on the axle have been torched, and I welded the upper gusset in (took my time not to warp housing).
Last night i tore out the old rotors and wheel bearing races. Then drove in new Bearing races, put on new vented rotors, and put on the wheel spacers.
Tonight if i can get time I will try to polish the welds on the axle and paint her up along with the knuckles and steering arms. Once dry I will slap that axle back together.
I will get pics on assembly of the Front axle. I forgot my camera the last few time i worked and I was more worried about progress than pictures.
== Merged Post ==
