Some have asked here on the PBB how to convert a 4x2 tranny into a 4x4. It's a bitch and not worth the time unless you already have both transmissions and want to use one as a parts donor.
What you need is:
4x2 tranny
Rear case from a 4x4 tranny
Output shaft from a 4x4
Counter shaft from a 4x4
What you do is swap all the gears, syncros and bearings from the 4x2 output shaft onto the 4x4 output shaft.
Make sure both donors are from the same year. These are D series because it is what I had laying around.
Internally, they are almost the same shiet. All the bearings on both transmissions had identical numbers and matched each other. All but 1st and 2nd gears are also identical.
So here's how you do it...
Remove transmission first dummy!
Remove bellhousing, it's dirty in there.
unbolt this
then this
Remove the main casing bolts, pretty easy so far.
Go take a leak and drink a beer because it's all downhill from here
What you need is:
4x2 tranny
unbolt this
then this
