Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > General 4x4 Discussion
Old 09-22-2007, 12:34 AM   #51
redranger4.0
Member # 25325
Send a message via AIM to redranger4.0
Originally Posted by skipped_Link View Post
Yes, but the good news is I saved a ton of cash by switching to geico
My theory is with the right spacers, & the bolt tight there should be no leverage on the bolt, only "shear", I could be wrong, maybe one of the mecanicle engineers will chime in, I cannot give good explination other than by looking at it I think the rod end will be the weak link,
I would say you suck at constructive criticism but you have a valid thought.
Im only a Mech Eng student, but the theory behind a bolted joint is that the bolt shouldnt have any shear forces on it, in all technicality. That it is the clamping force of the bolt with friction is what gives it strength. So the bolt shouldnt matter as long as the bolt itself can take the clamping force needed for it to work. Now that is in a perfect world. In the non perfect world. Aka the real world, there is going to be some shear on the bolt, which is why a larger bolt is better. Now if someone wants to jump in and correct me feel free, but that seems to be what I remember from Strength of Materials.
redranger4.0 is offline   Reply With Quote
Old 09-22-2007, 04:03 AM   #52
wyldstallyn73
Member # 40162
DAMMIT!! thought than when I got to my home computer I would be able to see the pics--I can only see the first 6 or so. Anybody know why??
Skipped, from what I CAN see, those are the exact same axles I have except for three things- 1-mine have planetary reduction hubs, 2-Unfortunately mine are not both steering axles. 3-my center sections dont have as many studs holding them in (early variation??) shit, mine even have the same yellow paint!!
I was thinking of doing the same cut and weld on mine when the time comes. Arent the ends of them a cast piece that is welded to the mild steel housing?? did you cut them where the weld already was, and did you use any special techniques or rod/wire to rejoin them??
"Time you shut your cake-hole, YOKO!!!"
wyldstallyn73 is offline   Reply With Quote
Old 09-22-2007, 08:45 AM   #53
HickTrucksRus
Member # 27040
Send a message via AIM to HickTrucksRus Send a message via MSN to HickTrucksRus
Originally Posted by gfbgreaser289 View Post
how about a build thread on that ford in that avitar?????
I just read his build thread on evolution's forum and damn. the 49 is probably the most bad ass show/mud truck ever.
this video will explain it all. I hope this buggy is a 1/4 as cool as your ford man.
http://videos.streetfire.net/video/8...df91e8770b.htm
When in doubt throttle out.
HickTrucksRus is offline   Reply With Quote
Old 09-22-2007, 09:13 AM   #54
B&L Truggy
B&L Truggy's Avatar
Member # 91246
very nice work. you have put some thought into it thats for sure.
B&L Truggy is offline   Reply With Quote
Old 09-22-2007, 09:14 AM   #55
The Twister
Member # 15774
looks awsome ! can't wait for the updates.
The Twister is offline   Reply With Quote
Old 09-22-2007, 10:52 AM   #56
FatMeats12
Journeyman Smoofer
FatMeats12's Avatar
Member # 31804
skipped,
seem slike I have seen that double ended ram somewhere, did you get it off of surplus center? Curious how good there stuff was.
FatMeats12 is offline   Reply With Quote
Old 09-22-2007, 01:21 PM   #57
skipped_Link
skipped_Link's Avatar
Member # 37865
I agree, and stand corrected, If there is a failure, I will post it & see if a conclusion can be drawn.
I'm not sure if the ends are cast or forged, I cut the tubes about 2" in from the factory weld, that way I was welding strictly to the mild steel housing, having two weld seams in one tube was another reason for the truss on the front diff, I did not use any special rod, just LH 7018, I did pre heat it a bit & let it cool slow,
Originally Posted by FatMeats12 View Post
seems like I have seen that double ended ram somewhere, did you get it off of surplus center? Curious how good there stuff was.
Yes that is the surplus center ram, just by looking the quality looks ok, we'll see how it takes a beating,
I am running Seans ram from Performance off road on the 49 & like it really well, I just wanted to try these out.
I know I said I would have more pics today, but I forgot the camera at home, maybe I'll make some progress tonight after work, then I'll have somthing new to post tomarrow,
skipped_Link is offline   Reply With Quote
Old 09-22-2007, 03:30 PM   #58
jrod66
Member # 42436
Looks good brutha, only a two seater? kinda big for a two seater, cool none the less though, I ran a surplus center ram on my rig for a year or so and had no problems with it, I plan on buying two more for the new rig.
BSW
[url]http://www.youtube.com/user/jrodd66[/url]
jrod66 is offline   Reply With Quote
Old 09-23-2007, 07:48 AM   #59
skipped_Link
Member # 37865
Yeah, I'll deal with it though, shouldn't you be posting another build thread here soon?
I did not really get enough done last night to even say I acomplished anything, however I did remember the camera so more pics,
Here is the clocked t-case & tranny mounts I mentioned earlier,
lower link frame mounts from the top side, here you can see the rod ends & misalighnment spacers,
Upper link frame mounts from the top side, also with rod ends & spacers,
Upper link front diff mounts,
And a pic of the finished motor mount,
A slight change in plans, I've decided to start working on the tranny tunnel & seat mounting, that way I have an idea of how high the B pillar will need to be, so that is what I will be working on tonight,
Old 09-23-2007, 08:27 AM   #60
CTENG
Member # 30371
Unfortunately this is incorrect. That bolt will indeed have shear on it. It will be loaded in a combined shear and bending. As long as the nut remains well torqued the bending force will be transfered to the spacer effectively making the bolt diameter equal to the diameter of the spacer with respect to bending. The full shear load will be taken by the bolt itself, but the larger load component will be the bending force.
The strength of this setup will depend on high torque load on the nut as this will put the bolt in preloaded tension and counter some of the bending stress on the compression side of the bolt.
If you were to calculate the friction force, even with clamp-up, over that small area of the spacer face, you would find it is far too small to be effective.
CTENG is offline   Reply With Quote
Old 09-23-2007, 11:11 AM   #61
RawPower
RawPower's Avatar
Member # 43894
I know it will probably be strong enough as it is... but any reason not to plate the sides on either the top or the bottom (or both if you aren't concerned about bolt access)?
I mean... I am under the impression that you are going to fully thrash this thing
1993 F350 7.3 IDI, ZF S5-42, 205, Rocks, 145" wb.
Wanna buy it?
RawPower is offline   Reply With Quote
Old 09-23-2007, 11:58 AM   #62
skipped_Link
Member # 37865
Well I know I said completed motor mount, but actually when it comes back apart for finish welding I want to cut a plate that will fit between the two ears, mostly to keep the ears from trying to flex, & keep the plate bolted to the block from bending around the mounting bosses on the block,
Good observation by the way, I guess I'm going to have to try to remember to be more specific,
Oh, and you are correct, this thing will have a beating handed to it every chance I get,
Old 09-23-2007, 01:15 PM   #63
the glassman
the glassman's Avatar
Member # 33365
Send a message via MSN to the glassman
Here is one of the rotors & the beginning of a rotor/driveline flange adapter,
Drilling the pattern for the rotor to bolt on & the two different flanges,
Parts bolted togeather,
Next came the claiper mounts, I chose GM 1/2 ton calipers for the simplicity of mounting them,
Cutting parts out
Test fit,
Modified caliper mount welded to my flange,
[/quote]
any way we can get some specs on this set up.
Mainly the adaptor for the rotor and if it would fit a top loader yoke, and if so i sure could use 4 of them
any specs on the caliper mounts
BUILT XJ AND YJ
THERE IS ALWAYS A CHEAPER YET STILL EFECTIVE WAY TO DO ANYTHING
the glassman is offline   Reply With Quote
Old 09-23-2007, 10:57 PM   #64
HydroDynamic
HydroDynamic's Avatar
Member # 65066
I like this thing.
HydroDynamic is offline   Reply With Quote
Old 09-25-2007, 01:52 PM   #65
the glassman
Member # 33365
updates
BUILT XJ AND YJ
Old 09-25-2007, 02:30 PM   #66
SPEEDCRAVIN
Member # 30432
You have some good ideas and good craftmanship... Subscribed
JOSH
[B][SIZE="5"][COLOR="Blue"]WWW.ANVILRECOVERY.COM[/COLOR][/SIZE][/B]
GOT TULIP? yep and he's GOT HIPPIE!!!
[SIZE="3"]CHECK OUT MY SHOP BUILD WITH APARTMENT[/SIZE] [url]http://pirate4x4.com/forum/showthread.php?t=589523[/url]
SPEEDCRAVIN is offline   Reply With Quote
Old 09-25-2007, 03:34 PM   #67
TOY 2
TOY 2's Avatar
Member # 12800
looks good I'll have to come out and see this in person.
TTC 08 or 09???????????
[COLOR="Red"][SIZE="4"]WWW.TBICHIPS.COM[/SIZE][/COLOR]
If you need fuel injecion chips programmed Brian is the man!!!
TOY 2 is offline   Reply With Quote
Old 09-25-2007, 06:38 PM   #68
mustange70
Member # 41097
Send a message via MSN to mustange70
Man you are now going to have 2 of the coolest play toys i know of, wow.
The way of building the frame/chassis is wicked and i may have to "take" some ideas from this (as well as you 49 build, as i happen to have a 49 sitting back home on the farm . . . . dammit i'm gonna be broke till i retire lol).
no offense. . . . . . . . . . . .but go fawk a blender :flipoff2:
Some of you were poked in your soft spots as babies....
I think someone needs to drink a big glass of Settle The FUCK Down
It’s kinda like sex ed in junior high. You put stick A into hole B and out pops a baby
mustange70 is offline   Reply With Quote
Old 09-28-2007, 01:16 PM   #69
skipped_Link
Member # 37865
I'm not sure what the rotors are for, they were an ebay deal,I'm sure some thing similar could be built for a top loader,
& as for the caliper mounts, they are stock gm 1/2 to mounts, cut appart & welded to my flange to bolt to the pinion retainer,
I'm just hoping to have it done by christams right now,
Are you sure you can make it all the way out here??
Old 09-28-2007, 01:28 PM   #70
JeepJerrySeinfeld
Member # 49828
Send a message via AIM to JeepJerrySeinfeld Send a message via MSN to JeepJerrySeinfeld Send a message via Yahoo to JeepJerrySeinfeld
very nice, can't wait to see more.
Rest my Beautiful son Braeden your dad will always miss and love you.
JeepJerrySeinfeld is offline   Reply With Quote
Old 09-28-2007, 01:33 PM   #71
skipped_Link
Member # 37865
Ok, time for some update pics,
Here is what will be the base line for the floor, notice it is about 2" below the upper frame tube,
Seat mounts are done, (yes I'm using these seats, maybe not the most comfortable, but very tough)
Bending up the B-pillar,
B-pillars that is,
A-pillars bent up & tacked in place,
Old 09-28-2007, 01:34 PM   #72
SlowmoSU
"Whinerboy"
SlowmoSU's Avatar
Member # 26608
Send a message via AIM to SlowmoSU Send a message via Yahoo to SlowmoSU
what kinda speed pills you poppin to get it done by christmas... do you have a normal job ?
Bottoms Up Rock Racing
A.J. Condon Driver of #4414
Teammate to #515
The Timberwolf -TW2 The Rebuild For Racing - By Tim @ LII
Cell - 410-259-3577
SlowmoSU is offline   Reply With Quote
Old 09-28-2007, 01:55 PM   #73
FrankenToy
Lobstetrician
FrankenToy's Avatar
Member # 36822
That's the exact same method I use to get multiple bends on the same plane with my M3. I would really like to say, "Great minds think alike!", but in my case this is just a coincidence...
"Having sex makes straight people gay and turns gays into Mexicans. Everyone goes down a notch." - Peter Griffin
White, straight and Conservative. How else may I piss you off today???
I'll keep my money, guns and Freedom. You can keep the "CHANGE"...
FrankenToy is offline   Reply With Quote
Old 09-28-2007, 02:13 PM   #74
skipped_Link
Member # 37865
more pics
Actual seat mounts,
Upper windshield bar & roof bars
Thats pretty much it for now, I'll be racing this weekend, so it will be a few days before there is anything new to post,
Old 09-28-2007, 02:23 PM   #75
skipped_Link
Member # 37865
No pills, & I do have a job, but we work 12 hr shifts, so I never have to work more than 5 in a row & never get less than 4 off, so I have plenty of time at home, the reason I am so optomistic about christmas is almost all of the expensive parts are paid for & here ready to put on.
Sure works good,
I've been trying to stay away from "multi plane" bends, I really want to see how nice "looking" a machine I can build using all single plane peaces,
Forum Jump
