Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > General 4x4 Discussion
Old 11-25-2007, 04:51 PM   #1
draggbody
draggbody's Avatar
Member # 60913
honda powered kid buggy... ***FINISHED W/ PICS***
with all of the complaining about boring build theads i decided to hold out til i was a little more complete... i decided to build this for my daughter... she is seven and a true sport about wheelin', camping, being outdoors, etc... she has been saying that she has wanted a buggy she could drive and really started pestering me after we went to harlan and she was seeing those RZR side by sides everywhere... shes like see daddy, you could just buy me one of those.... $10k+... cough, cough.... so after being inspired by rockapes build i desided to build my own... 3/4:1 scale....
i had a set of 31" boggers, freebie, i wanted to keep it small and low and narrow... i need it to fit sideways on my trailer that i tow my camper and buggy on... so i se my eyes on a set of sami axles, offset diffs and narrow... then i got a set of late 90's dodge 1500 wheels that i machined to larger hub bore, they were 16s that i needed for my tires... i used a 93 civic for a drivetrain, 1.6L vtec sohc and an automatic...
the next, and most important order of business was safety... i wanted everything to be kid sized, seats, seatbelts, steering wheel, pedals, you name it...
i decided to use one links front and rear mainly for simplicity, clearance, and protecion of the driveshafts... i want her to be able to just plow over anything w/ no concern as to damage on the under carriage... she would have no concept of damage anyways... enough blabbing, on to the pics...
this is what i started w/, a honda drivetrain, a set of sami axles and some boggers...
i listed this on our local board so i am cutting and pasting alot of the text so it my seem a little choppy...
11-2-07
82" WB, pontential cage height of 62"... the cab is tight as frog pussy, but i think it is going to be fine... the master cyl will mount in the rear, so nothing will need a "firewall"... these are at full stuff...
11-4-07
update... i got some work done this weekend, spencer and i set the engine up on the "subframe" and mounted the first piece of tube, which is the hardest by far... i did realize that i will need a wider set of axles, which are from a newer models... made one of the tranmission/ driveshaft adapters, the motor mounts are done...
this is the mounts
flanges...
link to honda powered kid buggy...
http://www.pirate4x4.com/forum/showthread.php?t=633445
K5 based buggy w/ tons, big block and 1410 everything...
draggbody is offline   Reply With Quote
Old 11-25-2007, 04:54 PM   #2
draggbody
draggbody's Avatar
Member # 60913
11-6-07
rear one link is finished... here is the setup...
rear view...
the joint... yes, that mother sucker is HUGE!!!!
this is where the brake booster is going... that is behind the passeger seat, facing the rear...
Old 11-25-2007, 04:57 PM   #3
draggbody
draggbody's Avatar
Member # 60913
11-8-07
todays update... the majority of the cage is finished... i still have to work on the floor, but i am waiting on shocks...
Old 11-25-2007, 04:58 PM   #4
draggbody
draggbody's Avatar
Member # 60913
11-16-07
so it seems as though i have come to a screeching halt... visually that is... i am trying to work out details now... anyways... heres the progress...
rear motor mount...
exhaust... yes that is a polished stainless muffler w/ mandrel bent pipe...:finger:
this is the front side of the brake booster... that is the passenger side, behind the seat... the right side of the pic is the front of the buggy...
front driveshaft/ pillow block... and how about fuck that fucking mother fucker of a front driveshaft... i have a 1 1/16 splined shaft, do the make a fucking pillow block that size??? of fucking course not... so i had to buy a 1 1/4 and then machine a bushing to make up the difference....
this is all under the passenger seat... front link mount, the jack shaft setup on the brake booster, and pillow block mount...
Old 11-25-2007, 05:03 PM   #5
draggbody
draggbody's Avatar
Member # 60913
11-18-07
this is my coilover setup... these are parts store shock "helper" coils and a 2" tube clamp... i dont take any credit for this idea as it was randy morris who thought of this... no other noticable progress today....
Old 11-25-2007, 05:06 PM   #6
csudman
Member # 23434
Send a message via AIM to csudman
Awsome, keep em coming.
[QUOTE=Tuesday]Did I miss something yesterday?[/QUOTE]
csudman is offline   Reply With Quote
Old 11-25-2007, 05:08 PM   #7
draggbody
draggbody's Avatar
Member # 60913
11-25-07
man am i getting jealous... i mean her buggy is going to be WAY nicer than mine... not to brag... okay, to brag the freaking fuel tank is nicer most rigs i have seen, this bitch is beautiful... all stainless, tigged, aircraft style cap... fucking sexy!!!! i made the gas tank "skid" and the radiator shield out of puched steel...
i am so pleased with the detail i am able to put into this buggy... hopefully i can start it next week and start teardown....
i added a little more cage... i feel 100% confident in letting my little girl roll this bitch as much and hard as she can now... my thoughts were to leave it as it was strong enough, but my gut was telling me to add more... so i went w/ the gut feeling....
gas tank and rear roll pan installed...
Old 11-25-2007, 05:08 PM   #8
PsychoticDeadGuy
PsychoticDeadGuy's Avatar
Member # 54093
This is a really cool idea! Props for doing the work yourself for your daughter!
'05 LLY Duramax
'82 6.2l K5 Blazer
Sinister Mfg. Company
PsychoticDeadGuy is offline   Reply With Quote
Old 11-25-2007, 05:10 PM   #9
toykilla5150
SMASHurai
toykilla5150's Avatar
Member # 65463
Send a message via AIM to toykilla5150
very kool! I want one now. how wide is it outside of tire to out side of tire?
I know somebody will say it so, Please biuld/put a shield under the orbital valve incase of a ruptured/pinhole in a hydro line. I have been cut wide open by a hydro line praying fliud out of a pinhole. It was not fun.
I do love your idea
you cant fix stupid
natural selection is a bitch!
toykilla5150 is offline   Reply With Quote
Old 11-25-2007, 05:10 PM   #10
draggbody
draggbody's Avatar
Member # 60913
11-25-07
this will give a little more porportion to the size of this thing...my back is touching the cage....
Old 11-25-2007, 05:11 PM   #11
draggbody
draggbody's Avatar
Member # 60913
BTW i am 5'10"
poser flex shot :rock:... acctually i had to check some clearances, but it is cool none the less...
Old 11-25-2007, 05:13 PM   #12
draggbody
draggbody's Avatar
Member # 60913
64" outside of tire to outside of tire... ~5 feet at ride height, 112" overall lenght... ~14" of belly height...
Old 11-25-2007, 05:18 PM   #13
jmdzuk
jmdzuk's Avatar
Member # 46888
I like ,keep the updates coming.
jmdzuk is offline   Reply With Quote
Old 11-25-2007, 05:21 PM   #14
Mosephus
Save the Hammers!
Mosephus's Avatar
Member # 56722
That's very cool, we don't have kids yet but I've been dreaming up something similar. Good Job.
Mosephus is offline   Reply With Quote
Old 11-25-2007, 05:22 PM   #15
muddermilitia
Under Destruction
muddermilitia's Avatar
Member # 76599
Send a message via AIM to muddermilitia
Your daughter is going to be the most popular kid in school! Looks awesome so far
89 K5 Trazer, TBI350/TH350, 203/205, 60/14bff, 52s/64s, 42" TSLs on beadlocks
For the best fullsize chevy parts: http://www.diy4x.com
Originally Posted by plug ugly View Post
Anyone can wheel a jeep
RIP Jason "WillysWanter"
muddermilitia is offline   Reply With Quote
Old 11-25-2007, 05:24 PM   #16
MattyB4x4
sharp as bluray
MattyB4x4's Avatar
Member # 32726
thats totally freaking cool. i'm really diggin all these "tiny" buggies
2007 silverado 2wd w/t
1990 Yota - SAS, duals + 4.7, 5.29's, locked, loaded, 40's
IGS Racing #404
Towable Pig Smokers and BBQ grills
www.diamondplateproducts.com
ΜΟΛΩΝ ΛΑΒΕ
MattyB4x4 is offline   Reply With Quote
Old 11-25-2007, 05:25 PM   #17
jhama78
nice roach.
jhama78's Avatar
Member # 3377
Send a message via AIM to jhama78
man thats awesome... looking forward to more updates..
-j-rOd
85 Roach Build Thread
85 Yota Trail Roach 223:1
85 SR5 xcab Quad Hauler
92 2wd yoter xcab fuel miser
Nobody ever lays on their deathbed wishing they'd spent more time at work...
jhama78 is offline   Reply With Quote
Old 11-25-2007, 05:30 PM   #18
suprdave737
Member # 49108
So its big enough inside for you to test drive it right? Also have you looked into arm restraints if kids are gonna be driving it? Very nice project thanks for sharing.
suprdave737 is offline   Reply With Quote
Old 11-25-2007, 05:33 PM   #19
94toytruck
94toytruck's Avatar
Member # 18614
Awesome that your building it for your daughter
Eric
94 toyota truck, well it started as one.... When exactly is it a truggy
www.rightcoast4x4.com
www.hillsidecustoms.com
ΜΟΛΩΝ ΛΑΒΕ
94toytruck is offline   Reply With Quote
Old 11-25-2007, 05:38 PM   #20
draggbody
draggbody's Avatar
Member # 60913
i am thinking about window nets, but she KNOWS about arms inside... granted she will not be following me on obsticles, more like a chase vehicle... it is tight for me, the seat is adjustable and fits my wife good, she is 5'... i will wear a helmet so i dont beat my brains out... she will wear a DOT/snell motocross helmet... i dont even let her ride in my buggy w/o it...
Old 11-25-2007, 05:41 PM   #21
Rock Ape
Member # 23843
Thats pretty damn cool....
I think your gonna be mad when this goes places easier that yours will!!! Are you planning to have some kind of speed limiter on it??I know mine would be more power than I would wanna turn a kid loose with,without some kind of limiter.
I told my wife I would just move the pedals closer on lo-budget pimpin for my little one when she gets big enough.But for now Im gonna have to fine tune it until then.....
THANKS TO MY SPONSORS....TFAB,TRAIL-GEAR,YUKON,TORCHMATE AND RUFFSTUFF!!!
Rock Ape is offline   Reply With Quote
Old 11-25-2007, 05:44 PM   #22
habitatxskate
Member # 53705
amazing, my lil sis is 3 and she loves lifted trucks and mud already. she plays in my truck all the time. my dad wants to start her on a quad then from there not really sure.
liftedtalk.com
habitatxskate is offline   Reply With Quote
Old 11-25-2007, 05:47 PM   #23
draggbody
draggbody's Avatar
Member # 60913
i want to look into a top speed limiter... i know they can remove it, i am just wondering if they can reverse whatever does that and "restict" it... i dont want to reduce the power as it may be neccesary for hills etc... i will do mechanical stop if all else fails... i will also start her out in like 2nd gear and not tell her about the others as she will think that she will tear something up if she puts it in 3rd or 4th....
Old 11-25-2007, 05:48 PM   #24
dethmachinefab
Fluid Power
dethmachinefab's Avatar
Member # 101113
Send a message via AIM to dethmachinefab
The build looks tits, nice work. The load leveling shocks work great for little buggys, i have used them on mine but found the rebound to be a bit slower than id like. Cant wait for action shots.
big fuel-black smoke
dethmachinefab is offline   Reply With Quote
Old 11-25-2007, 05:53 PM   #25
Mustard Dog
Chubby Chaser
Mustard Dog's Avatar
Member # 7889
Send a message via AIM to Mustard Dog
Very cool
Eric Anderson
TIN BENDERS
Hendrix X Chassis #013
Spotter F-Toy #028 Team Marlin Crawler
KOH #66 4Wheel Parts, Raceline, PSC, Bilstein, Marlin Crawler, LightFORCE, BFG, HendriX, PacificFab.net, Longfield
Roxy's in the industry and I'm a sponsored professional driver. The two of us together make a powerhouse.
Mustard Dog is offline   Reply With Quote
Forum Jump
