Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Toyota - Land Cruiser
Old 04-09-2008, 06:44 PM   #1
zach 38
zach 38's Avatar
Member # 88131
Talking The Best Carb?
im looking to get rid of my stock carburetor from the strait 6 f motor on my fj40 and im thinking about geting a holly for it but what kinde should i get? i have a friend that has a holly 400 on his fj40 and likes it, but i would like to no what other people have on theres and what they like or do not like about it. im planning on haveing it as a light wheeler and a DD.
zach 38 is offline   Reply With Quote
Old 04-09-2008, 06:53 PM   #2
turnmeover
turnmeover's Avatar
Member # 105563
go with the downey tbi conversion. Increased milage,hp, and torque . Nor do they flood on extreme angles.
turnmeover is offline   Reply With Quote
Old 04-09-2008, 09:13 PM   #3
Eskimo
Eskimo's Avatar
Member # 10429
The best carb has fuel injectors sticking out of it.
q-jet is a distant second, with everything else behind it.
Rich Q.
FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/42's
Eskimo is offline   Reply With Quote
Old 04-09-2008, 10:16 PM   #4
PJohnson
PJohnson's Avatar
Member # 263
Aisin carbs are very well engineered for the vehicle. I would just rebuild it.
BTW, welcome Noob
Phil
1966 FJ45 LPB
1973 FJ40, beeropener
http://www.mta4x4.com
TLCA Chapter Delegate, TLCA#9166
Increasing my post numbers one pad at a time...
Support the innovators of our sport, buy from Marlin Crawler
http://www.marlincrawler.com
PJohnson is offline   Reply With Quote
Old 04-09-2008, 10:27 PM   #5
65SWB45
Desert Rat
65SWB45's Avatar
Member # 27432
There are places on the web where you can post up that you are willing to trade your Aisan carb for an aftermarket and you will get plenty of offers for just about any aftermarket carb you desire. Makes you stop to wonder what they know that you don't.
MarksOffRoad.net
Originally Posted by lc tpi
...if I have to buy them from Trail Gear I guess I dont need them.
65SWB45, 64LWB45, 68FJ40, 72VJ40, 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer
tlca #1086
member: Trail Crew-L.A. TLCA, Elwood Chapter, TLCA
65SWB45 is offline   Reply With Quote
Old 04-09-2008, 10:47 PM   #6
Pooze
Pooze's Avatar
Member # 104239
With the stock 6 I liked the weber, i have heard a lot of things on the Holley if you drop the float 1/8 and extend the overflow at a 90 that it is a great carb also. I was just told that by a few people dont really know from experience though.
1978 FJ40,383 stroker, 350,205,corp 14,dana 60 detroits 5.13's 42" Irocs, and a little tubing.
1971 FJ55,om617,sm420 in the process
2004 F250
http://www.delalbright.com/Rubicon/buy.htm
http://www.sharetrails.org/
Pooze is offline   Reply With Quote
Old 04-10-2008, 02:56 AM   #7
DHONDAGOD
4X4HIM.COM
DHONDAGOD's Avatar
Member # 34369
Holley carbs SUCK on a wheeler... Period...
If you want to have your carb rebuilt and made to work the way Toyota intended it call this guy;
http://www.marksoffroad.net/index2.html
Chris
Originally Posted by Earl_of_Burl
Q: What is Hell?
A: A place that is without God.
Q: How do you find God to avoid Hell?
A: Through his son, Jesus Christ.
Q: What does this mean to me?
A: If you are living your life without accepting Jesus Christ as your personal savior, you are on the road to Hell.
DHONDAGOD is offline   Reply With Quote
Old 04-10-2008, 09:16 AM   #8
dog walker
Super Moderator
dog walker's Avatar
Member # 156
Send a message via ICQ to dog walker
For performance, I like the weber 38mm, but it'll cost you over $400 to get started, then it'll rape you at the gas pump. I've retrofitted a couple Motorcraft 2bl's on F engines with very good results, you can pick them rebuilt from you're local parts house for under a $100 and either use a Holley adapter or make you're own. Motorcrafts work as good as quadrajets off road, and you can get them in the 350 cfm range unlike a quadrajet which I think is more like 600-750 cfm.
Jeff Fretwell
dog walker is offline   Reply With Quote
Old 04-10-2008, 03:00 PM   #9
fj40charles
Member # 1926
I recommend a TBI carb...
'69 FJ40 with very few stock parts.
2000 Cummins with some goodies to make it smoke.....
Trail Gear's Bad Ethics=Bad Business.
fj40charles is offline   Reply With Quote
Old 04-10-2008, 07:07 PM   #10
wayneraintree
Trail Riding Life
wayneraintree's Avatar
Member # 16988
I had a Weber.... ate fuel like crazy.
Stock ran well and worked well offroad once rebuilt (went this route a couple times from Marks and Jim C.).... overall, a great choice.
Then I got a diesel and...
I had the downey EFI kit... PO installed it, didn't idle right, I could not get it right....
Consider a a 3FE FI conversion from junkyard stuff... intake, sensors, air intake, fuel pump and computer...not 100% sure it would work on an F but 2F is documented.
Have any pics of yer 40? I could opinionate moreif I saw it
JV Rally post #546
Tellico Rally post #138
Stay well,
Jeffrey
wayneraintree is online now   Reply With Quote
Old 04-10-2008, 07:20 PM   #11
bustanutley
Member # 23362
Send a message via AIM to bustanutley
Webber 38 runs great once you tweek them, they are almost always jetted too rich, i stepped mine down a bunch, but I am also a mile high. Milage was good the last time I drove it on the road. You need to drop the float level so they don't flood at angles, and breather extensions are a good idea also although I have yet to do that.
The stock carbs work very well when in good condition, they are a bit more complex though. Getting your stock unit rebuilt by a pro is your best bet.
1970 FJ40 rollin on foDees!
HOMEGROWN
bustanutley is offline   Reply With Quote
Old 04-10-2008, 08:29 PM   #12
Killerpee
Member # 14712
[quote=wayneraintree;8125073]
Consider a a 3FE FI conversion from junkyard stuff... intake, sensors, air intake, fuel pump and computer...not 100% sure it would work on an F but 2F is documented.[quote]
Any links to some threads on a N/A Fuel Injected 2F using 3FE stuff??
Needed:
Volvo chromo portal gears
Killerpee is offline   Reply With Quote
Old 04-11-2008, 05:47 AM   #13
wayneraintree
Trail Riding Life
Member # 16988
[quote=Killerpee;8125374][quote=wayneraintree;8125073]
Here is the article from Toyota Trails:
2005 J/A Arron Thompson FJ62, Version 2F-E
MUD thread with a whirrlllllllll http://forum.ih8mud.com/40-55-series...o-my-fj40.html
more Pirate cruiser discussion:
http://pirate4x4.com/forum/showthrea...&highlight=2FE
JV Rally post #546
Stay well,
Jeffrey
Old 04-11-2008, 06:53 AM   #14
wayneraintree
Trail Riding Life
Member # 16988
http://forum.ih8mud.com/40-55-series...king-2f-e.html
more discussion: looks like you need later 2F flat top piston, just one of a few issues to address...
JV Rally post #546
Stay well,
Jeffrey
Forum Jump
