#1 |
Frontier4x4.com
Member # 35054
Frontier 4x4's 83 Toyota build
I've had this build up on my local club's forum and now moving it over to here.
I started with just over a month to get everything done for the first trip of the year, Howiepalooza. Some of the things I did are temporary just to get through this wheeling season. This is what happened in that month, I'll let the pics do most of the explaining. Traded some labor for truck(swapped a couple thirds) 1983 SR5 22r L52 5sp rears up front chevy rears doubler Sky's high steer Hydro assist 30 spline Longfields Longfield hub gears Hendrix 6 pin V6 calipers vented rotors IFS rear welded 4.10's square front driveshaft CV rear shaft t-case crossmember roll cage bobbed bed 17x8 beadlocks 36x13.5x17 iroks The truck is currently under the 2nd stage of the build up as of today. This includes: front tube work, dovetail complete rear tube rear 4-link propane conversion
www.frontier4x4.com Luke Graham - (515)441-0338 Facebook Fan Page 85' 4Runner Weekend Warrior Build 88' DD 4runner Build Frontier 4x4's 83' Trail Rig Build Last edited by lgraham09; 07-16-2008 at 06:23 AM. |
#2 |
Frontier4x4.com
Member # 35054
This is how it looked after driving it home on 3 cylinders. First thing I did was check the compression and found out #4 intake wasn't closing. I adjusted the valves and got all the compression back and running smoother than any 22r I've ever had.
I then changed the leaking intake gasket, blocked off the egr, and removed all the extra vacuum lines. Did a tune up and changed all the fluids. ![]()
www.frontier4x4.com Luke Graham - (515)441-0338 Facebook Fan Page 85' 4Runner Weekend Warrior Build 88' DD 4runner Build Frontier 4x4's 83' Trail Rig Build |
| Sponsored Links |
#3 |
Frontier4x4.com
Member # 35054
While I waited on parts, I bobbed the bed ~9" and swapped in an IFS rear axle
www.frontier4x4.com Luke Graham - (515)441-0338 Facebook Fan Page 85' 4Runner Weekend Warrior Build 88' DD 4runner Build Frontier 4x4's 83' Trail Rig Build Last edited by lgraham09; 07-16-2008 at 05:08 AM. |
#4 |
Frontier4x4.com
Member # 35054
My rims showed up (Cragar 17x8 2.5bs) so I got the 36x13.5x17 iroks mounted up and on.
specs here, post 289: http://pirate4x4.com/forum/showthrea...197981&page=12 ![]() ![]()
#5 |
Frontier4x4.com
Member # 35054
Next was the rear chevy springs
#6 |
Frontier4x4.com
Member # 35054
Rears up front. The truck had 2.5 skyjacker springs on it front and rear. I used the skyjacker rears with one extra cut down leaf from the rear of my 88 4runner.
I replaced the front spring hanger and tapped and installed the IFS box. Replaced the front axle with another built axle(longs, hub gears, brakes.) ![]() ![]() ![]() ![]() ![]()
www.frontier4x4.com Luke Graham - (515)441-0338 Facebook Fan Page 85' 4Runner Weekend Warrior Build 88' DD 4runner Build Frontier 4x4's 83' Trail Rig Build Last edited by lgraham09; 07-16-2008 at 05:42 AM. |
#7 |
Frontier4x4.com
Member # 35054
Installed front shocks and hoops. Mounted up rear shocks.
#8 |
Frontier4x4.com
Member # 35054
doubler installed, made front square driveshaft.
#9 |
Frontier4x4.com
Member # 35054
Cage went in next, along with transfer case crossmember, seat mounts, floor.
#10 |
Frontier4x4.com
Member # 35054
Beadlock kit showed up so that went on next.
Write up here: http://pirate4x4.com/forum/showthread.php?t=683180 ![]() ![]()
#11 |
Frontier4x4.com
Member # 35054
That put me up to the weekend before Howiepalooza with a bunch of little things to finish up. I welded in some door bars and took off for the weekend.
#12 |
Frontier4x4.com
Member # 35054
The last day out there we where headed back to the trailer and my front axle locked up about 10 feet from the trailer. I unlocked the hubs and got it on the trailer ready to head back home. When I got back, the driver side upper trunion was gone and all the roller bearings were jamming up between the outside of the longfield and the inside of the knuckle ball.
#13 |
Frontier4x4.com
Member # 35054
I had another complete axle so I swapped all the goods into that one after welding some armor and gussets on. That's the only fix I needed to do before the next trip a couple weeks later to Dresser, Wisconsin for the Memorial Day run.
#14 |
Frontier4x4.com
Member # 35054
Everything worked great at Dresser and came back with little carnage. The only things need fixing were getting replaced anyway. I came back with a cracked frame above the driver side factory spring mount and the upper shock crossmember is bent. The worst part is I have to replace a fitting on one of my rear shocks that hit the bed after the crossember bent.
#15 |
Nice, clean, build
80 First Gen Locked 38.5s bobbed doved propane 63s rears full hydro... SAVE UPPER TELLICO POST #456 |
#16 |
Good clean job as usual.
85' 4Runner - AP extreme lift, 37" PB Rockers, duals 88' 4Runner SR5 - current project 97' Tacoma - 2.5" OME lift TLCA Member# 16265 |
#17 |
Clitoris Cowboy
Member # 100827
Nice ride, what brand weld on beadlocks are those?
01 Dodge Ram 1500 sport 5" lift 35 Mud grapplers 87 Sas White Trash Poor Runner |
#18 |
chicken fucker
Member # 2931
cool truck, the tube work/Tcase crossmember and sheetmetal on the floor turned out bitchin! great lakes beadlock rings?
http://www.diamondaxle.com http://www.F-O-A.com http://www.12voltguy.com http://www.addictedoffroad.com wanted: (2) 12''x3''x250# coilover springs 2002 diamond axled coilover/linked tacoma v6 4door rock taxi with dual cases and beadlocked 37s |
#19 |
Member # 115163
#20 |
Member # 8553
Where are the pics of the progress on Cole's rig
Ummmm Beer |
#21 |
Member # 99589
Can never get enough of the first Gen's. Great looking rig
[SIZE="5"][URL="http://www.pirate4x4.com/forum/showthread.php?t=721051"]Buy my truck:D[/URL][/SIZE] |
#22 |
don't taze me bro
Member # 85972
nice build.
before you criticize someone, you should walk a mile in their shoes. you'll be a mile away from them, and you'll have their shoes. limit straps http://www.pirate4x4.com/forum/showthread.php?t=855647 dimple dies http://www.pirate4x4.com/forum/showthread.php?t=856146 |
#23 |
Member # 87189
looks good. i love the first gens. looks like you may need a beefier tie rod though....
SCTC/CA4WDC for sale: [url]http://pirate4x4.com/forum/showthread.php?p=9904790#post9904790[/url] |
#24 |
Member # 100958
slick.
![]() Tie-rod bent?
88yota ice breaking MACHINE, welded rear, yota 8" front, 8" welded rear, duals and hydro soon |
#25 |
Member # 109466
So i have a few questions. Beautiful truck by the way. But welded 4.10's with 36's? how do you like that? and how do you like the welded front? thanks man
| Thread Tools | |
| Display Modes | |
