Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Toyota - Truck and 4Runner
Old 09-30-2008, 06:34 PM   #1
NE-89-4Runner
double duty
NE-89-4Runner's Avatar
Member # 87247
89trailrunner Project Double Duty
Decided to start my own build thread, it will probably take me a little while and a few posts to catch up to today... but for now, here's what I started with, an 89 4Runner, originally from FL, bought from eBay and shipped to RI. Objective is a capable rig that I can still drive to work everyday, it is my only vehicle.
None of the typical New England rust
Not knowing the history of the engine with 157K on it, I decided to do the timing belt, front main seal, and valve cover gaskets. When disassembling for the timing belt I found that it had jumped a tooth:
Needless to say that was corrected, along with another crankshaft pulley. Mine was spun, the outer pulley had separated from the inner portion, meaning that when the camshaft pulleys were aligned, the crank pulley would not show that it was on TDC... making it impossible to set timing.
NE-89-4Runner is offline   Reply With Quote
Old 09-30-2008, 06:35 PM   #2
NE-89-4Runner
double duty
Member # 87247
Next was gears. Got a used factory 4.88 rear for $100 on Craigslist, and a $100 front from someone on 4x4wire. Ordered the solid pinion spacer from Trail Gear, and a Lockright. My pattern seemed a little off to me (before teardown), but ZUK (gearinstalls.com) told me that if it was set up that way from the factory to run it. It was a little tight, but should be OK (About 18K miles later, I'd say he was right - zero issues). I tightened up the carrier bearing preload and put it in.
Old 09-30-2008, 06:39 PM   #3
NE-89-4Runner
double duty
Member # 87247
Then I found plans for a budget tube bender on eBay (www.gottrikes.com).
Can't say enough about how great this bender is, you'll see some of the stuff it produced in following posts...
First (and easiest) thing on the list was sliders:
plenty of offroad pinstripes!
Old 09-30-2008, 06:42 PM   #4
NE-89-4Runner
double duty
Member # 87247
Time to ditch the stock/aftermarket springs and lift blocks for something a little more stout.
The beautiful shackles:
Out with the old and in with the new...
Lots of grinding later to get rid of the old shackle hangers and replace with new
Old 09-30-2008, 06:46 PM   #5
NE-89-4Runner
double duty
Member # 87247
Rear bumper as it looked:
complete with MI ORV sticker ;D
Bumper removed before brackets were cut from the body
wish i had taken a pic of my trailer hitch before it was torched off, but this is what I left on to use as part of the attachment to the frame.
these pieces of plate will be welded to what was my trailer hitch, with 4 additional tube supports under the truck welded to the frame.
Then I measured and bent up some tube
to attach to what I salvaged from the trailer hitch for a receiver
Old 09-30-2008, 06:49 PM   #6
NE-89-4Runner
double duty
Member # 87247
On to the rear bumper.
Side supports cut and notched
tacked in place
all tacked up ready to be welded
Old 09-30-2008, 06:53 PM   #7
NE-89-4Runner
double duty
Member # 87247
endcaps:
bumper mock-up before paint
finished product
on a side note...
Old 09-30-2008, 06:55 PM   #8
NE-89-4Runner
double duty
Member # 87247
Out with the old:
and in with the new:
flowmaster 40 series muffler, welded to a factory pipe coming off the cat, running straight out the back through 2 1/4" pipe, all welded...
added a factory style roundbar hanger forward of muffler, and a universal hanger at the tailpipe bolted into one of the factory holes for the original rear bumper.
positioned the rear hanger tilting foward to keep it further from my shackle:
Old 09-30-2008, 06:58 PM   #9
NE-89-4Runner
double duty
Member # 87247
Then more parts arrived:
V6 to gear case adapter
10 degree clocked adapter
23 spline 4.7 gearset
two gear cases, and marlin triple drilled flanges. top shift for the rear 4.7 install on the left, 23 spline turbo case for the reduction box on the right
Old 09-30-2008, 07:06 PM   #10
NE-89-4Runner
double duty
Member # 87247
rear case torn down, case being cleaned
case clearanced for 4.7's
Old 09-30-2008, 07:07 PM   #11
NE-89-4Runner
double duty
Member # 87247
rear case finished, on to the crawl box
Old 09-30-2008, 07:09 PM   #12
NE-89-4Runner
double duty
Member # 87247
pic for myself for reference and anyone who is going to want to do the same thing.
fork shift getting ready for modification
Old 09-30-2008, 07:24 PM   #13
NE-89-4Runner
double duty
Member # 87247
the forward shift rail and fork is now a top shift rail and fork, modded as described previously
pre weld:
fully welded up:
cases finally assembled:
Now it's just a matter of the crossmember, driveshafts, console, time, etc...
Old 09-30-2008, 07:25 PM   #14
NE-89-4Runner
double duty
Member # 87247
then started on the front winch bumper... ;D
Old 09-30-2008, 07:37 PM   #15
NE-89-4Runner
double duty
Member # 87247
bumper done, at least to the point where it is on the truck. still needed to add two braces from the ends to the frame where it will be welded. I fully reinforced the front crossmember similar to the fror brace, and added a length of 3" angle iron above it with holes drilled in it and nuts welded to the back to replace the factory upper bumper mounts... just need to add tabs for my hella's
was happy with how it came out... then ordered the winch to fill in the hole...
Old 09-30-2008, 07:44 PM   #16
billybob13
don't taze me bro
billybob13's Avatar
Member # 85972
nice build. and nice thread too. everything clean with good pics... you sir, are multi-talented.
before you criticize someone, you should walk a mile in their shoes. you'll be a mile away from them, and you'll have their shoes.
limit straps http://www.pirate4x4.com/forum/showthread.php?t=855647
dimple dies http://www.pirate4x4.com/forum/showthread.php?t=856146
billybob13 is offline   Reply With Quote
Old 09-30-2008, 07:53 PM   #17
blackrider
jdsoehyr ncvhud
blackrider's Avatar
Member # 37690
Send a message via Yahoo to blackrider
ya i was going to say something like that also.....
only thing i can add is maybe adding some diagonals to the rear bumper;
from the receiver to the frame rails...
if you pull hard at an angle something will bend....
4.3 tbi/vortec,4dees,samurai tub,toyota running gear,duals,4 linked,coil overs,oba,full hydro,stauns,full exo...
NotQuiteRight Wheelers
YouTube - samurai wheeler 5/08
http://www.youtube.com/user/notquiterightclub
blackrider is offline   Reply With Quote
Old 09-30-2008, 07:53 PM   #18
NE-89-4Runner
double duty
Member # 87247
then obviously the next thing is a SAS...
housing to be modified for an e-locker, regeared to match the rear
axle as it arrived:
elocker torn down:
Yukon 4.88's, solid spacer, trilpe drilled flange and setup kit from Marlin:
Old 10-01-2008, 03:57 AM   #19
knixen
Member # 79934
Send a message via MSN to knixen
Nice build! Good skills!!
x2 on reinforcing the rear bumper...
Knixens runner... diesel, the works... :laughing:
knixen is offline   Reply With Quote
Old 10-01-2008, 05:06 PM   #20
NE-89-4Runner
double duty
Member # 87247
There is going to be more bracing underneath - two pieces coming from the rear of the center tube near the hitch receiver to the inside of the framerails, and a piece on each side wing going up underneath to the outside frame rail. I've got them cut and fitted, just haven't put them on yet...
Old 10-01-2008, 05:12 PM   #21
NE-89-4Runner
double duty
Member # 87247
spring perch took a little grinding to get proper fit for the u-bolt.
using housing as a guide for drilling to mark center for pilot holes
two short stud pilot holes drilled, marked for the long studs to see where to weld additional material
lots of welding/filing/fine tuning here
Old 10-01-2008, 05:35 PM   #22
NE-89-4Runner
double duty
Member # 87247
e-locker carrier with new bearings and ring gear installed
axle housing mods finished for the e-locker...
Old 10-01-2008, 05:39 PM   #23
NE-89-4Runner
double duty
Member # 87247
Set up the front diff, first attempt with .077 pinion shim revealed this pattern:
drive side:
coast:
A tad deep, but not too much. If it was the rear I would have tried again, taking off a couple of thou, but being the front I let it ride.
Old 10-01-2008, 05:46 PM   #24
Mawnov
Member # 48072
Dam fine Job! Excellent job so far, keep it up!
85 4Runner with some stuff.
Mawnov is offline   Reply With Quote
Old 10-01-2008, 05:59 PM   #25
smewhtguy
Clitoris Cowboy
smewhtguy's Avatar
Member # 100827
Very nice work sir.
01 Dodge Ram 1500 sport 5" lift 35 Mud grapplers
87 Sas White Trash Poor Runner
smewhtguy is offline   Reply With Quote
Forum Jump
