Custom Rock Crawler Expedition Jeep
aka: The Dragon
Rated 4+ Trail Expedition Jeep TJ year 2000
This is not a pretty boy jeep! This is a well build extreme tested, extremely dependable Custom: “Rat Rod Style”, “the Real McCoy", “General of Jeeps” Comes with scars & scratches and Adventure stories...yet, well maintained, care for, well loved & never abused.
This is a Jeep for a mature person who wants an extreme duty all terrain vehicle capable of climbing inclines of 70 degrees, traversing rocky terrain at 40 degrees, forging 3 foot of water…crawling over 12 foot waterfalls with ease. This is not a “Trailer Queen”… this rig can cake walk over “boulder stew”, and then drive at 65mph with cruise control smoothly down the freeway. All above is tested and driven by me…the only one owner.
Note: Of course the lucky new driver of this Jeep will have to feel what is right for the vehicle and for themself, according to the terrain before driving extreme angles. I can share with the new owner my experience of driving on different terrain and the in and outs of this Jeep.
Drive train:
Custom 4” wider Dynatrac 60 Axles Front & Back with High Pinion 35 Spline Alloy and ARB Air Lockers, 4.56 gear ratio. 1350 U joints,
Altas twin stick 4.3 Tranfercase with 32 Spline output front and rear.
24” longer than stock tj wheel base at 118” Custom Rubicon Long Arm Suspension with adjustable shocks, Currie anti sway bar, PSC Hydraulic Assist Ram Steering System with 1 ton Dynatrac High Clearance Steering.
39.5 Super Swampers: IROK 8 ply bias tires, with Run Flat Staun Internal Bead Locks on 17” steel wheels, 4 wheel Disc Brakes with Balance Masters Active Wheel Disc on all four wheels.
Protection :
Driver and Passenger Air Bags, 1/8” Aluminum Doors, Rockhard full cage inside, External Windshield Roll Bar outside, Chromoly front Bull bar, 3/16” bottom side slider,
1/8” steel body side armor , 2x4 ¼ thick rear bumper with 1” tabs.
Skid plates for: engine/ transmission/ transcase/ gas tank/ radiator/ rear brake lines. Front and Rear Differential Protection.
Recovery: Warn HS 9500 I High Speed Winch with extra new cable for extension plus removable Mile Marker 2500 Winch for custom hitch system set up on all side. Four hitchs: one on each side of jeep for self recovery. Pull Pal military grade anchor.
Comfort: AC/ Cruise Control / Heater / Expedition “Maggiolina Extreme” (designed for off road use) Auto Home: Instant easy crank up/All Season 2 person, dust & water proof Sleeping Accomidations.
Hot Man: exact temperature Hot Water/Shower
Custom Cab with 2 tops and 2 sets of windows: one set is soft top material with vinyl windows, one set is soft top material with sturdy sliding glass windows.
Accessories: Maxxon 45w CB with 10 ch NOAA weather band radio. Public address speakers with 101 bird & animal sounds…10 different alarm sounds.
24 volt Portable Mig Welder, Extreme Air continuous duty Air Compressor and 4 gallon Air Tank with quick disconnect 4 air tools and air up tires.
Solar Panel, PIAA Rear Lights, Side Lights, HELLA Black Magic Long Range Lights, GPS, XM ready radio, 2 stage Double Ram Bottle Jack. Expedition Rack with Telescope Awning, All season Extreme Auto Home. ARB snorkel….and more…………………!
Photos at http://picasaweb.google.com/travelingtao/JeepForSaleAkaDragon#
Working on Art Business project ,Need money
Over 80K invested …will…Sacrifice at $ 42,000 obo
Located near Lake Havasu ARIZONA
Contact : Ray 763-772-2383
Email : travelingtao@gmail.com
