#101 |
Member # 123460
This is my rig. 1980 chevy 1-ton chassis, shortened 40 inches, dana 60, 14 bolt, locked front and rear, full hydro streering, 350, turbo 400, 203-205 doubler, 38.5 boggers, with a 1989 jeep yj body on top. I have more in tires than I have in the rest of the rig.
![]() This was the first time I drove it after building it. Damn cows make those ponds soft. ![]()
#102 | |
Member # 126882
97 chevy duallie with sas an 38 85 crewcab chevy 2.5ton rocks an 44 boogers |
| Sponsored Links |
#103 |
1978 F250 Custom - Fun truck 1996 Dakota - Daily driver Last edited by Nitrofueled14; 01-26-2009 at 07:56 PM. |
#104 |
Member # 83084
![]() this is my 67 j-3000 on a 79 chevy 1 ton shortened 11" running 355/ th400/205 clocked down and in this pic had 60/14 538s locked f/r , she has 12" superlift in front shackle flip in rear fully caged front to rear running 49" irocks at this time shes in shop getting rockwells locked up f/r hyd steering and 388 full roller motor and few other goodys will post up some build pics |
#105 |
texASShole
more info on the mini rock/mud buggy please.
Nothing worth noting here Last edited by wes8517; 01-29-2009 at 11:56 AM. |
#106 |
Member # 125311
Location: Sittin' here doin' my part to make sure the welfare checks cash.
![]() 80 degrees of solid wet rock Videos http://www.youtube.com/watch?v=SDpSU...eature=related http://www.youtube.com/watch?v=a9fR_r2wA58 CUSTOM 4X4 RAILBUGGY/ ROCKCRAWLER Its a 4X4 buggy made out of a 300 Arctic Cat 4X4 atv. It has 15 gears so it will pull like a tractor and climb any hill. 130:1 crawl ratio. JUST SOME OF THE ITEMS ON IT *Custom built 1" 3/16 wall tube frame,tree bars and front bumper *Full under body skid plate *Motor and suspension from a 2000, 300 Arctic cat "Motor only has (about)557 original miles" *Electric start or pull start *Pro Circiut type 496 exhaust *Air cooled w/ oil cooler *Custom chrome air intake *6" UNI foam air filter *Outer Wear filter sleeve cover *4 gallon fuel cell *5 speed Automatic *Hand shift w/ 3 range transmission-SUPER LOW>MEDIUM>HIGH RANGE *REVERSE* *Optional 4x4 or 4x2 by the pull of a lever *Speedo,Lighted Instrument Cluster w/ Oil,Temp,Nuetral,Reverse,Head lights,Gear position and LED- Reverse Light toggle switch *Halogen Head Lights, One spot and one flood *Reverse Halogen Flood and Tail light *Four wheel Independent suspension *Wheel base is 7' axle to axle *Outer Wear Shock covers *Custom brake and gas pedal *Steering Stabilizer *Rebco quick detach 3 spoke steering wheel *Disc Brakes *Wilwood master cylinder *ITP SS Machined Aluminum-Painted Wheels *ITP Mudlite Tires 26X10 front, 26X12 rear *Race bucket with adjustable seat rails *Cushioned Seat Cover * Four point RCI race harness *Small tool box "for wrenches" *2" ball mounted on rear *new cvs and axles *new red boot gaurds *3000lb winch with wireless remote *new 8.5" steering rack Its for sell http://www.pirate4x4.com/forum/showt...549&highlight= Last edited by 78FORD4x4; 01-30-2009 at 05:01 PM. |
#107 |
Member # 112915
The Slime. Maybe $100 put into this truck.
#108 |
Member # 128238
#109 |
Thank you, some day it will all be redone.
1978 F250 Custom - Fun truck 1996 Dakota - Daily driver |
#110 |
Member # 128238
That will be really cool. I actually don't get to see many of them type's of Ford's up here, nice to see you put stacks on your truck. I love it when trucks have stacks... gasser or diesel!
#111 |
Member # 107258
stacks a ghey
#112 | |
Baaaaaby ruths
Member # 50585
hell , the tech aint even that great over there to begin with, all it is is a bunch of oe nerd masturbating to spid sheets and parchment colored trim and noob want to dsic swap and drop there truck, seriously building a truck you would only need to be apart of that board for about 2 days |
#113 | |
Sure doesnt show you making it up the "80 degree wet rock" any further though.. gee, thats cool. In all honesty, it does look fun though.
85 3.4 V6, 38s, Longs, 4.7 Marlins, 5" AP springs.. almost done..www.chucktownlowdown.com |
#114 |
nice roach.
R.I.P. Neal Welch 2/4/09...
You will truely be missed by family, friends, and fans...
-j-rOd 85 Roach Build Thread 84 Yota POS semi retired 85 Yota Trail Roach 108:1 85 SR5 xcab Quad Hauler 85 GMC C3500 Dually Tow Hoe 92 2wd yoter xcab fuel miser Nobody ever lays on their deathbed wishing they'd spent more time at work... |
#115 |
Member # 603
What happened?
www.gumbo4x4.com Thanks to: www.heiseroil.com Extreme Performance www.kmelectronics.com Bear Creek Auto Recyclers www.svrehorsepower.com |
#116 |
Member # 115688
My old truck, not really a mud truck
![]() ![]() 1/2 ton sucks!!!!!
#117 |
Member # 40162
"Time you shut your cake-hole, YOKO!!!" |
#118 |
nice roach.
It was not racing related, i just got a call yesterday saying that he'd passed on.
thats all the details i know right now. The south east has definitely lost a legend in Mud racing with his passing. his website hasnt been updated in a while but it still has some pretty cool old pics and some vids... http://welchracing.com/main.html
#119 | |
Member # 100822
#120 |
Member # 9041
Sorry for you're all's loss.
Here's my rig ![]() '83 K-5 60F 14B lincon'd rear 5:13's Dropped spring perches for the clearance. Needs more engine but that's in process
Give it just a little more, you'll make it Last edited by mudtrux; 02-15-2009 at 09:14 AM. |
#122 |
Member # 67732
My K5
engine- 383 roller motor, about 540 hp and 530 tq tranny- built th350 with ultrabell bellhousing, ati sprag and red clutches np208 xfer case. i have 3 spares. right now 44/14ff both open 4.11's. this spring the d60 is going in and both getting welded. i also have the hydro steering setup ready to go on with the d60 full cage is being installed as we speak. 38.5 boggers 6" rough country lift, no blocks Oh, and a nitrous works dual bar setup... hehe. ![]() ![]()
I'm not totally worthless. I can always be used as a bad example Last edited by dnchevyman; 02-17-2009 at 05:59 PM. |
#123 | |
Member # 110281
#124 |
![]() mostly trails and rocks.....but being in the midwest she sees her share of mudd
97 Ranger Excab shortbox 114"... One tons, 351w, C6, 205, 39.5 TSLS |
#125 |
Member # 67732
yup, i broke a short shaft yoke the first trip out. havent done anything crazy since then, just mostly dirt fields playing around. but they definately break. i brought 2 spare shafts out with me on wheeling weekends.
I'm not totally worthless. I can always be used as a bad example |
| Thread Tools | |
| Display Modes | |
