#1 |
Leaf Spring Dimensions FAQ
As someone who is always building 4wd vehicles, its nice to know leaf spring dimensions, to see what will and will not work in certain projects.
I'm trying to compile as much leaf spring information as possible. Please post up any specifications you may know. Right now the best website out there for this information is DRM's side: 4x4spot.com 79-88 Toyota 4wd Rear 20.5/27.5 long 2 3/8" wide 18mm/18mm or 14mm/18mm spring eyes. 88-98 Chevrolet/GMC 1500 31.5/31.5 long 2 1/2" wide .5625/.5625 spring eyes. Centered eyes. 61.5" Deaver Rear Springs 27.5/34" long 2 1/2" wide .5625/.5625 or .75/.75 spring eyes. Front reverse eye, rear centered eye. Marlin/Trail Gear/All Pro front springs: 21/26" 2 3/8" wide 18mm/18mm bolt size. Marlin/Trail Gear/All Pro Rear Springs: 27.5/29" 2 3/8" wide 18mm/18mm bolt size All Pro 05+ 1.5" rear springs 55 1/2 OAL , 27 3/8 Pin to Front , 28 1/2 pin to rear . Wrangler YJ: 22.5/22.5 2 1/2" wide Stock Toyota Front: 22.5/22.5 2/ 3/8" wide 18mm/18mm bolt size
Garrett Matt Performance Driving & I4WDTA Certified Off Road Training Last edited by GRMhick; 03-25-2009 at 11:34 PM. |
#2 |
It would be nice to know approximate lift and overall lenth eye to eye with the split and flat length
| Sponsored Links |
#3 |
Lift is variable on spring rate and the weight of the vehicle. Most leafs do not have a linear rate, but are close. But thats a good idea to add. Spring rate is something that should be added.
Garrett Matt Performance Driving & I4WDTA Certified Off Road Training Last edited by GRMhick; 03-25-2009 at 04:23 PM. |
#4 |
Bird=The Word
Member # 38006
I found this chart on another thread might be useful.
Better to have it and not need it, than need it and not have it. |
#5 |
I'm a little teapot.
Member # 44480
Awesome!
#6 |
The Quiet One
I'll have to admit I haven't touched that page in YEARS... mainly because comparatively speaking - aftermarket springs are light years better than they were 10+ years ago when some of us were forced to build spring packs because that was the only option aside from dropping $800+ on custom springs.
Glad to see some people keeping the fire alive though
>David > 4x4Spot.com >It only hurts the first time you agree with me... >"A little nonsense now and then is cherished by the wisest men." >***FOR SALE: 87 4Runner / 60's / 3link rear / 39" PitBulls - $7500*** |
#7 |
Alcoholic Brohamski
There is some good info in the FAQ on a page that lists lots of lengths and widths, but the addition of your extra info is welcomed.
http://www.4x4spot.com/misc__spring_information.htm |
#8 | |
Ford Bigot
Member # 31227
Garrett you got some of it a little off:
F150s are 57" long, 26/31 (5/8, 9/16) Early (73-79) Wagoneer rears are 57" long, 25.5 / 31.5 (9/16, 9/16) You can add that to the spreadsheet. Also you should clarify fronts and rears as most people are not leaf spring junkies like myself and can't identify a front from a rear simply by length.
'45 Ford GPW - 108" wheelbase '84 Toyota SR5 '08 F-250 My GPW buildup -> http://www.pirate4x4.com/forum/showthread.php?t=775559 |
#9 |
Project "Curly"
Member # 124547
would this be an appropriate place to discuss how leaf springs work? I.E. whether or not all leaves contribute to lift and/or load capacity
tree huggers.... Don't give them reason to burn our playhouse down |
#10 |
Good link to give you some information about spring rates:
http://www.therangerstation.com/tech...springrate.htm
Garrett Matt Performance Driving & I4WDTA Certified Off Road Training |
| Thread Tools | |
| Display Modes | |
