#1 |
machinist
Member # 66259
some brake tech...
so, everyone is all about replacing their lspv with a new proportioning valve and new brake lines...or wire tying up the arm for the lspv...etc. well, if your brake lines are in nice shape, and your lspv is working properly, you can easily turn it into an adjustable proportioning valve and leave your brake lines intact. i had my lspv off, but it's not necessary to remove it.
i don't have the exact measurements, because i made it on the fly on my cnc mill (lathe wasn't hooked up yet), but if you aren't a moron, you could remake it on a lathe, or drill press out of just about any material you wanted. the black plastic part in the one pic is the original piece held in by the c-clip that the arm goes into. the brass piece is what i replaced it with. it is tapped for a 1/4-20 bolt. voila. |
#2 |
Member # 129568
Sweet! I am gonna try that tommorw
There's no shirt like no shirt 96 grand 89 yota 44/14bolt |
| Sponsored Links |
#3 |
Member # 89153
That's some good FAQ material right there. Nice work.
#4 |
Drive a First Gen
Member # 89727
awesome..
'81 Trekker Wheel Responsibly, Don't screw it up for others... Remember to Thank a Vet |
#5 |
Member # 102813
Nice, clean and adjustable (great to fine tune, wire method not so much)
Thanks!
My friends call me "The butcher" I feel like I stole this bing from Billy....http://www.pirate4x4.com/forum/showthread.php?t=847699 |
#6 |
I'm a little teapot.
Member # 44480
Yellow stars are expensive...but would you make these in exchange for
#7 |
Yah......
for you!Another thing to add to my "make" plans. Thanks
Yoats n stuff |
| Thread Tools | |
| Display Modes | |
