41 - 60 of 309 Posts
Discussion starter · #50 ·
Thanks to man kinds evolution you can now put down the BFH hammer and torch and give us a call. The DIY 20 ton press brake will produce accurate repeatable bends over and over again.
I have everything listed on the website in stock ready to ship out.
Thanks again for the orders.
Troy
Discussion starter · #52 ·
Is the back stop removable? Looking at the pictures it looks like it may be bolted on, am I seeing the right? Would be nice if it was removeable for storage.
Correct, the back stop and two guide rails can be unbolted with two 1/2" nuts.
Troy
Discussion starter · #56 ·
How wide is the V die opening?
1.75" opening which makes a nice tight bend in the metal you are bending. If I were to use a larger opening you would be able to bend thicker metal, however this press brake is designed for the guy bending up tabs and brackets up to 1/4" thick in the shop and looking for a nice tight bend radius.
Troy
Troy
Any chance in making a 2 or 2.5" die?
how much for the kit shipped to 60517 and where do i send money?
Max thickness
I'm not endorsing this, but I just bent 5/16" x 4" to 90*. The bend turned out great, but I was sure nervous doing it. I'd say the max I would even try is 3/8" x 4", but that's pushing it and you may not get a full 90*
If they made a 2.5" V die you could do ~6" of 3/8
A 3" V die would allow ~8" of 3/8 and full width 1/4" (19")
Discussion starter · #60 ·
I'm not saying no to your request, however give me a couple weeks to test this out. It requires a several new parts which we will need to source, draw up and have laser cut.
Anyone else looking to bend 3/8" plate?
Troy
