Building an overhead vehicle "lift" (car display ramp)
1 reading
22K views 8 replies 5 participants last post by  7.62FMJ
#1 ·
OK, so I know you've seen new and used car lots displaying a car/truck on steel ramps. Well, what about using one of those as a substitute for a 2 or 4-post lift?
I don't have the room, foundation, or money for a lift...but have tossed around the idea of building a ramp to accomplish nearly the same result. Obviously, the vehicle would have to be running to get onto the ramp. Or, I could rig up a pulley system and use a winch or another vehicle to pull it on.
I would probably build it out of 2x2 or 2x3 tubing somewhere around 3/16" thick and angle iron for the tread. Maximum load around 8,000 lbs.
Now, it will also have to be mobile and not take up too much space (it will be used outside, and possibly stored inside an outbuilding). So I was thinking I could build each side seperate, and just use a couple pieces of tube to link them together while erect (with hitch pins or bolts). I could also attach a couple pneumatic tires to one end and wheel it around.
I stand 6'5" tall, but even I think building a rack 7' tall is out of the question. I guess I'll keep it around 4' and sit on a shop seat...
I'm just in the planning stages now. Any thoughts?
http://www.myautodisplays.com/pdf/Flatline-Ramps.pdf
#2 ·
for $50 dollars I bought a ramp style lift from a fellow. it has very large c channel for the car to ride on and it is also used for the height for the ramp with a base on it. you drive up the ram and it tilts to level and then you put in a piece of channel in the back for support. It is only off the ground about. 30in. though. And is ridiculously heavy. But for the price I hauled it home. He was using it for his corvette in the shop. and he had the place and space for a 2 or 4 post lift.. I bought a large I beam from him as well for 10 bucks and made giant gantry for other projects ED
#5 ·
There is one just over an hour from me for $300. It is only 30" tall, and looks a bit old and flimsy. I can't tell from the usual CL shitty, grainy, 100' away picture he put up. It's also a tilt style, which I do not want. I could alter it, but if I'm going to do all that I will just build one.
Yeah, I definitely considered that before getting my lift, but I never could bring myself to consider it acceptable. It just seemed hokey to me, but that's personal opinion. After building an RTI ramp it was even more tempting to build a second and at least work on the vehicle parked on the slope.
As an interesting aside, check out this wooden version for a Mustang
http://www.svtperformance.com/forums/terminator-archive-208/98085-perhaps-my-greatest-mod-pics.html
Not gonna debate good idea or bad idea. It's, um, creative.
It does sound like more work that it's worth...mainly with setting it up and taking it down after each use...but with 4 trucks, I'm sure it will get some good use in a short time. I've been working on my newest truck quite a bit (wheel bearings and seals, brakes all around, complete fluid change, front-end bushings, etc...).
My CTD is 2WD, so I have to drag out the car ramps anyways and squeeze my big ass under it for oil changes.
It just kills me anymore to climb under and around a truck for hours on end. And in a gravel driveway no less.
The only part I haven't figured out yet, is how I will be able to lift the vehicle off it's wheels while on the ramp. Or unload the suspension. If not, I could always save those jobs and just do them on the ground like always...
#4 · (Edited)
#9 ·
That's kinda what I was thinking. Although to support the weight across a 5' span, it would probably have to be a piece of thick channel or I-beam (or multiple pieces of square tube?). And I would still have to stack some 4x4's on it to get the bottle jack within lifting range.
Re-reading what I just wrote, it sounds like a death-trap... :laughing:
