I'm sure mine in the front is lighter than most, and I'm running 175/300. One of the problems you're going to have is getting an initial spring rate that is soft enough to compress that 18" coilover to reach your ride height. My XJ buggy with the 175/300 springs is a 110 primary rate, and compresses my 12" shocks 6". You'll need a primary rate that will allow your shock to compress enough to reach your desired ride height, yet not be too soft. Looks to me like you'll need a 3rd tender coil so you can go with a higher initial spring rate. I'd do some calculations using around an 800 lb corner weight, and see what you come up with.
For example, if you figured an 800 lb corner weight, and wanted to set the ride height with 8" of available suspension compression, that means 8" of shock shaft showing, then the springs/shock would be compressed 10" (from full extension) at your ride height. 800 lb corner weight divided by 10" of needed spring compression would give you a primary rate of 80 lbs/in. That's pretty soft, too soft, and if you figured the frequency it would be very soft. Now, if you used a 3rd tender coil, with no spring rate, and shorter coils, you'd compress the shock 4" with no spring rate, so now you'd need to compress the springs 6" (rather than 10") to reach your desired ride height. So take the assumed corner weight of 800 lbs divided by 6" and you come up with a primary rate off 133 lbs/in, which is much better and could be close to what might actually work. BTW, your idea of 250/300 is a 136 lb/in primary spring rate.
I know this is a different subject, but 18" is a lot of travel in the front, are you sure your steering and drivelines won't bind with all of that travel?
