Pop Rivet Weight Capacity
16K views 27 replies 8 participants last post by  adrianp918
#1 · (Edited)
3/16" pop rivets.....how much weight can they hold?
Working on installing new drawer slides in my rolling craftsman tool chest
#2 ·
I bought this rolling box on CL for $100
I've never seen a locking 3 digit code roller before
All drawers are ball bearing and the casters are 6"x2" and a greaseable
For $100....its a good find!!!
Anyways, the bottom deep drawer needs a new ball bearing slide on the right side
The slide bracket is marked Accuride
No one, and I mean no one makes a replacement slide for this box
I found slides at Lowe's for $25, which have a 100 pound per slide capacity
I used three rivets per slide, when attaching it to the inside of the box
I was only able to use two rivets per slide, when attaching the actual drawer
I greased the bone dry castors at the fittings and am amazed how smooth this box rolls
Bad slide:
Good slide:
#5 ·
The answer depends on a LOT of factors, including: materials (steel or Aluminum rivets; alloy; temper; nail?); rivet wall thickness/nail diameter; whether the nail stays inside the rivet; mounting surface wall thicknesses & materials; and presence of a reinforcement washer.
#6 · (Edited)
Normal ole aluminum nails still inside
Should I put some glue on the end to make sure the nail doesn't come out?
The tool chest was obviously steel, and made well since its a tad older
I'll keep an eye on it and see if it loosens up at all
#7 ·
The box is about 33-1/2" wide, 18" deep and about 42-1/2" tall
The large greaseable castors are great
I found a manual online, which is for a similar box......I wish I could find a part or model number for the box, no luck
Here is the finished box, with the slides I used
#10 ·
steve83:34137505 said:
Why don't you separate the slides, add rivets, and add another pair of slides for the big drawer? It's already made for 2 slides per side.
Two slides per side is an option, if need be
The factory setup only had one per side
#11 ·
You can buy accuride slides but I am assuming you are saying they do not make one with the mounting tabs yours has. ?
I had a accuride slide on my snap on box pull apart like yours. I was able to put it back together and it works fine. It takes some fiddling with and some tweeting of the retention tabs but you should be able to put it back together.
Plan A, put slide back together
Plan B, buy same size generic Accuride slide and scavenge parts need off it to rebuild yours
Plan C, rivet replacement slide on.
#17 ·
Accuride doesn't sell a direct slide replacement
Waterloo doesn't either
#18 ·
I contacted every slide manufacturer with the accuride slide part number I wanted.....trust me, I tried
This is a discontinued slide and no one sells or makes it
These slides work, hopefully they hold up
I think the 5 total rivets will hold just fine
#20 ·
From Waterloo:
The accuride slides are no longer available and there is no substitutes for them. Thanks and have a great day.
Karla Williams
Customer Service Representative
Waterloo Service Parts
#21 ·
From Accuride:
Hi,
Thank you for contacting Accuride technical support.
The slides in the tool box are custom made, you can tell because of the mounting tabs, to get an exact slide replacement you will have to contact
tool box manufacture.
Regards...
Jorge Perez
Technical Support Analyst
Accuride International
#23 ·
So this may be off topic but what is the weight a pop five can carry
I have a1/4 sheet of steel being held against my food trailer wall and I want to mount two 100 lb propane cylinders to that sheet...I have about fifteen to twenty rivets holding that plate on, will the rivets hold in place with the weight of the cylinders and LP??
Sent from my iPad using Tapatalk
#24 ·
No. Either run a bolt through the whole wall, or use a bracket to the tongue.
Are you looking at mounting it on the tongue? 6' of angle iron, a dozen nuts and 6' of 3/8" rerod could make a bracket that wont move?
Aaron Z
#27 ·
So you want to put it in the back so when someone rear ends your trailer it burns up? I would still connect it to the frame and run bolts through the body (with a big spreader plate on the inside).
Aaron Z
#28 ·
Aaron Z
After your comment and consideration to the safety of it ...I think I will leave them on the tongue where it seems to be safe
